overheating
cuprakris
leon cupra
Dec 28, 2008
84
ipswich
hi all,
im hopeing one of you lovely lot have experianced this, while driving my car to work this morning my water temp gauge went up and the light come on so i pulled over straight away and the temp went straight down again i looked at the water and it had not used any atall, so i carried on to work with it not reading as high but the next line over 90, and the same problem occured on my way home from work but didnt read 120 it read the line just before and once again no water used could anyone help.
thanks.
nicksxjr
Revo....whiplash!
Jul 24, 2009
254
Somerset, taunton
sounds like common symptoms of water pump breaking up! the water is not circulating therefore getting hot around the engine! the best way to tell is when the cars warm the two pipes going to the radiator will vary in heat!
