Since buying the Passat I've covered about 44,000 miles - and during that time, the temperature guage has stuck firmly at 90º (except when warming up from cold, obviously...) regardless of outside temp, driving style, etc etc.
About a week ago, I got a warning on the dash display to "Check coolant level". Sure enough, it had just dropped below minimum in the expansion tank - so I bought some G12 coolant and topped it up.
Couple of days later, I was giving it some serious beans up a hill (Cat'n'Fiddle road, if anyone knows it) - when power went down quite dramatically. Looked at the gauges, coolant temp was almost at full scale, must have been around 120º. Nowhere to pull in so drove very gently - and within 30 seconds max it was back to 90 again, and power was restored. Stopped and checked coolant level - it had gone down a bit.
Since then, the temp stays at a constant 90 all the time, EXCEPT when I give it a prolonged blast at full load. Then it starts rising quickly. Calm down and drive normally, and it's back to 90 very quickly.
Coolant level is now back down to minimum level, so reckon I've lost a litre or so in the last week.
Had cambelt and coolant pump changed earlier this year at 120k miles.
Any ideas ?
In summary:
- Temp only rises during prolonged full load
- Fine during normal driving or when in traffic
- Drops back to 90 very quickly if I ease off
- No abnormal smoke
- Performance normal (except when overheating, guess the ECU cuts power)
- Idles smoothly
- No mayo in oil filler cap
Not liking the sound of it
Any ideas ?
In summary:
- No abnormal smoke
- Idles smoothly
