guys, i need further
help with this
problem - in short my water pump bust so i got the warning and overheating engine. I have replaced the pump and the collant system is working fine however when i start the engine (even if its stone cold) or indeed simply when i turn on the electrics and not the igniton at all, i get the 3 beeps and warning light, it does it every time i drive!
i have replaced the header tank as was an easy 2 min job and have replaced the coolant temp sensopr and still no joy, any ideas?
this warning is a coolant level warning, which tend to come on when cold or in the winter months. The sensor has two prongs that go into the coolant, and i guess it works on conductivity. So when the coolant level is low, or temperatures are low and electrics dont work as effectively you may get issues with this.
just wait another month and there will be loads of thread on this issue.
Fixes inclue:
replacement of header tank and sensor. - which you have done.
cleaning / scrapping of the prongs.
Checking / imcreasing level of coolant.
Making sure the sensor contacts are clean and good.
If i was you id take a look at the coolant level when its cold. I suspect the coolant level while ok may be lower than it was previously. So if its ok but at the lower end of the ok range, top it up a bit. This helps in most cases.
If the coolant level is towards the top of the ok level but you still get the issue, given this has happened on two header tanks it could be the sensor contacts in the sensor plug / wiring. - however i assume if you turn off the ignition after a short drive and then on again it does give the warning? if so im sure topping up the coolant a bit will
help.
