Over revving issue
rich3001
137
My 1.2 has had a issue with over revving for about a month now. It happens when im stationary (idling) at lights and changing gear. When im changing gear i take my foot off the accelerator and push the clutch down and the revs rise (If i change at 2500 the revs will go up to 3500/4000) and then gradually go back down. Hope that makes sense. Ive changed coil packs, spark plugs (they needed changing) and cleaned out the throttle body. i did have a issue when the car took ages to respond when pulling away from a junction but that was a problem with the spark plugs. Any ideas what could be causing this? Any help would be appreciated. Thanks
daves ibiza
check white little switch plunger behind clutch pedal this happend to me and turned out to be white plunger
