Over heating problem?????????
Pecky24
last nite i went to work and driving at 60mph taking it steady all of a sudden my MY51 cupra overheated, once parked up the temp dropped bk down to normal temp.
been out to car this moprning and let it warm up and it appear that it does not start to over heat until u drive at over 50mph
there is heat in the heaters but half as hot as u normally get,
im hoping this is just the thermostat and nothing serious as the car performs like normal but any suggestions would be great
Nabraxas
111
It'll be the waterpump - mine went a couple of months back. You'll be changing the cambelt too when you get that done...
Pecky24
got my car bk 2day, water pump and cam belt changed, total cost of £274.75, happy i got the cupra back
and this after i fitted my HID main beam kit while the boss was out, dip kit was great main beam i think will light up china
Pecky24
standard 1 as the metal can cause major damage if they fail i read, but apprantly they redesigned standard pump to make it stronger
stevo lcr
75
Tividale
My cupra r is in for a water pump and cam belt,but it turns out it wasn`t the pump that failed,so ive got to wait for the garage to put it back together and then try to sort out what it is.I would have put money on it being a pump faliure (hot engine,cold heater etc) but maybe just a stuck thermostat?.It did need a cambelt though,so not too fussed!!
