Options for changing front windscreen wipers?
s_purs
They look great, thank you! Will be getting a set of them I think
s_purs
Hi,
Just called up a VW dealer and he couldnt confirm that they fit directly onto the Cupra arms. Could someone confirm I just need to buy the Aero Conversion kit wipers for the 2003 MK4 Golf? Do they need cutting down too?
Kat you got the part number for the ones you ordered as you said they fit directly onto your car with no cutting or anything?
Thank you
s_purs
In this thread: http://www.seatcupra.net/forums/showthread.php?t=206918
They said the part number: 1J2998002 is the aero blades that fit on standard arms?
Can someone confirm if this is the case please? As that comment was replying to someone asking about 'new style (flat) wipers' so just want to check it is the same bit and that the part number: 1J2998002 will fit directly onto my 04 plate mk1 leon cupra T
s_purs
Yes I am getting very confused with all the names and stuff! lol
I want the things Kat put on her car- which I understand is new blades onto a standard LC arm?
To do that do I just need to order the part number: 1J2998002 For about £27?
Which I assume is just the blades and will fix in fine with my standard arms on my car?
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Prices are roughly 70+ if not more now?
Second hand is good scour ebay for them.
Dead easy t fit some cut the passenger side down 1" or sit it higher o i trimmed my windscreen trim.
Someone loosened it and moved the pivot bit along the am a touch (good thinking that)
SWANSWAY CUPRA Dealership
