opinions please
Jun 24, 2007
967
durham
me and corby have just been and put the cars on the rr . i have revo who quote over 200 bhp with the map and corby has one of angel tuning . mine is the 1.8 t and corbys is the fr tdi . corby got 165 bhp and just under 300 ft lb tourque and i got some strange results my first run hit 189 but the guy said the heat sensor had fallan ontop of thr rad . then every run after that it went down they did agout 8 runs and it went from 175 to 162 in the last three runs . i rang revo and the guy said it could be the diverter valve split and i should upgrade to the forge one . After the rr sesion we went for a spin to see how the two compare we raced from 40/50 on and mine kept slightly pulling on the tdi by a few car lengths but if the rr is correct surely the tdi should quite easly pull on mine 165 bhp and 300ftlb tourque against 162/175bhp and 225 ftlb especially racing from a rolling start where the tdi is at its best :confused:
Jun 24, 2007
967
durham
shouldnt do in 4th you will get better grip
would the diverter valve being split give me these probs or would it be obviouse with the lack of power i would be getting . or should i just put it down to the dyno lottery as the car seems to drive fine and i am happy with the power :shrug:
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
dyno lottery but if the diverter valve had spliti think it doesnt alow the turbo to boast up so power would be lost and ud notice it! was it a power run or static this time luke?
Jun 24, 2007
967
durham
it was a power run how much would the forge valve cost and is it easy/ worthwile to do the turbo seems to boost properly all the time . and as i said surly if the figs are correct i should have got raped by the tdi
rashcupra
Oct 15, 2006
6,517
crawley
yer you should of done!
the forge r.v is so easy to fit any1 could fit it! and you should have 1 anyway! specially as yours is remapped! dont cost alot either
imo id definatly add that to your christmas list :santa:
DIFT
Torquing all the Torque
Oct 8, 2004
1,546
Kent/London
If they had to do 8 runs, in varying gears, doesnt sound too good.
I'd put it down to the RR/Operators.
Still upgrade to the Forge Valve for peace of mind :)
Jun 24, 2007
967
durham
it was all the same gear this time but the runs were done without a break heres the vids mine went on for about 10/15 mins so only got the ones at the start
DIFT
Oct 8, 2004
1,546
Kent/London
Is yours the FR? With the small side mounted intercooler?
If they did them back to back, thats not much of an oppertunity for the car to cool again... So could be heat soaking.
Jun 24, 2007
967
durham
thats what corby asked it had been thrashed for twenty miles there put straight on the rollers and the runs were done without even a slight break which you can see from the vid
Jun 24, 2007
967
durham
the graph
CORBY
272
Sunderland & Washington
What are you doing then Luke are you just keeping it the way it is or are you getting your money back? I think its fast as F**k yours like! Cos I can beat some quick stuff, and you can beat me!!
Jun 24, 2007
967
durham
just leaving it and saving up for the diverter valve and see how it goes . i am pleases with the performance so just going to put it down to a dodgy rr sesh
Ad Lav
vRS...
Nov 10, 2006
4,230
Kent
Shame about the results luke, the first run was good at 180 odd but it just seemed to get worse the more runs they did?!
