Hello all,
Now before I'm told to use the search function, I would point out that I have done this many times over on many forums and search engines. The results of which I have tried and still I'm not getting anywhere with my issue.
The dreaded lack of opening issue that is common on our (and other) cars, I will list below the way I have tried to open my door and the symptoms.
First of all the door in question is my rear offside and I've tried the following:
What I have tried:
The only thing I can think of now is to remove the exterior window sill and use something like this: http://www.amazon.co.uk/dp/B00ERBTE...TF8&colid=3L50S8EQL0JM1&coliid=I1SEF4K0W5OHR5
Or undo the bolts from the B Pillar hinges and try to wiggle the lock into opening?
If anyone has found a way to sort out this issue that isn't covered above please let me know.
- - The door will not open with two pulls of the inside handle.
[*]- The inside button does try to pop op with an inside handle pull, but not all the way.
[*]- The outside handle is free to move, but the cable from the mechanism is come out from its fixing on the exterior handle.
What I have tried:
- - Palming of the inside and outside of the door locking area has only resulted in a slight dent to the door
[*]- Using a coat hanger to try and hook the mechanism lever through the cable hole hasn't worked.
[*]- Door card cannot be removed from the inside with the door close as there is no access to bottom fixings. - - Screaming and the use of colorful language with threats has little effect.
