only drivers door unlocking !
mark smith
"take it or leave it !"
Oct 28, 2007
72
10
westbury !
went to open the car today, pressed the remote unlock once drivers door unlocked, pressed the unlock again to open the rest of the car and nothing happened could hear the drivers lock trying to do something ? so need to unlock the drivers door then press the button on the door to open the rest, any ideas ? ? ? cheers
mikeholroyd
This might not be relevant, but I had a very similar problem on the Octavia a few months ago. It turned out the battery in the remote was very weak, and was only giving enough power to operate the central locking when it was pressed only the first time. Second and third presses didn't allow the remote to properly sync with the car.
Try a new battery in the remote before condemning anything. If the central locking is working on the door switch, there's nothing wrong with the control unit.
Mike
Apr 22, 2010
505
Leicester
mine sometimes doesnt open the rest of the doors on a second press of the fob, works fine off the button in the car though. will be changing the battery to see if this helps at all.
Jul 8, 2007
514
i had the same pronlem as you mate altho mine was after i git my Headunit, All i did was take battery off for 15 min an when i put it bk on it was fine give it a go
Sep 18, 2009
2,443
Shropshire
getting the same problem. Was in the garage and they said the battery when low and they had to charge it, since then only the drivers door unlocks but all doors unlock ok from the button inside so just disconnecting my battery and waiting for 30 mins and see if that fixes it :D
Jonny's Leon
Ha! this happened to me, left the battery disconnected for an hour and presto all worked again fine.... weird!
