Ok to run engine with MAF disconnected?
Hicks
Let's nuke 'em from orbit
Nov 26, 2002
420
Relocated Yorkshireman
As subject says, I've been told it's ok to run the engine with this disconnected (I'm trying to determine if the MAF is faulty). If the engine works ok with it disconnected, what's the point of this component?
benjiwales
benji
Jan 29, 2007
297
Penybont
It's ok to run it for short term, as in just to see if the car improves (meaning you have a faulty MAF)
Longer running without will cause the car to run too rich (i think) and will damage the engine
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Its there for a reason, if the maf is faulty or disconnected, the ecu will use the default value as it cannot determine the correct air flow. The maf tells the ecu how air realy coming in and adjust the other compoments, eg fuel, timing, boost... so on.
The way i know if the maf faulty is use vag to show whats the max reading it give and if it below average, depening if the car is mapped or not.
