No sensor.
Yes it has !?
It should be in the sump, just above the drain :
Combined oil level & temperature sensor.
Pressure sensor is located at oil filter.
It is a single sender in the sump but the documentation calls it an oil level/oil temperature sender. However, I think it is a simple on/off sensor i.e. switches the output if the oil level falls below a preset minimum or the oil temperature exceeds a preset maximum.
The oil pressure sensor is separate and is mounted in the oil filter assembly. Again this is an on/off sensor.
Aye fair enough, there shouldn't be pressure in the sump as its gravity fedIt is a single sender in the sump but the documentation calls it an oil level/oil temperature sender. However, I think it is a simple on/off sensor i.e. switches the output if the oil level falls below a preset minimum or the oil temperature exceeds a preset maximum.
sorry oil?...
My coolant heats up in about 5 mins. Oil I reckon takes another 5-10mins. And like you my commute is only 20 mins, so I'm driving like a granny all the way. Occasionally I put my foot down but only after 10mins minimum, as I know it's at least warm. A bad idea?
