Right ive finally got sick and tired of my guages not having the backlighting wired up so im going to have a go at hooking them up this week.
Ive had a very thorough search and cannot find a definative answer to any of my questions below so if you know please lend a hand, if your going to tell me to search, save it
The only reason im having to post this thread is people have a knack for asking the same questions over and over again, then figure out the answer and never post back with the solution ****s me right off that does! So once ive got all this sorted i will make an effort to include a few pics of the wiring and the steps involved, think of it as an attache to Craig!'s guide
So...Ive got autoguage Boost and Oil Temp gauges in the car and basically need to know which colour wires go where.
Ive read Craig!'s guide and seen the photos of PhilW's wiring on the back of his headlight switch (pics attached at the end) but these still dont solve my problem
On the rear of the guages there are 4 wires:
Purple
Yellow
Redish/Orangish
Black
This is my old voltage guage (autoguage) which was never hooked up at all but it still has the same 4 wires out the back:
Now basically what im needing to know is:
1 - Where each of these wires needs to be connected to
2 - What gauge of wire to use to extend these wires so they can be connected down at the headlight switch
3 - Where to get said wire
4 - Where to earth the guages (in Craig!'s guide he mentioned earthing them on the engine as he was running a wire through there anyway, however i was wondering if there was a -ve/earth wire in the back of the headligt switch?)
5 - What guage of wire to use for the connection between the oil temp sender and the actual guage itself
One last question:
Does anyone know the thread specs of an autoguage oil temp sender? Is it M10x1 or 1/8 NPT as ill need to get a sodding adaptor if its the latter and id like to have everything i need ready to go when im doing it!
Pics of the headlight switch and PhilW's connections:
Any help would be very much appreciated
Purple
Yellow
Redish/Orangish
Black
One last question:
