Oil recommendations?
Cain1412
21
I have a 2021 seat Leon estate mk4, It will be having a service done soon by myself just wondering on what oil is the best to use for the car.
Yern
675
338
There should be a sticker under the bonnet above the radiator indicating the recommended oil viscosity.
ümit ceyhan
18
I opened a topic in the link below. If you want to evaluate what I found.
Reactions: Tell and Cain1412
Cain1412
21
Thank you for the help, so this oil ive attached in the photo will be okay.
KoNG
528
115
London
I would recommend sticking some better brands, for example, Shell, Castrol, and Total, especially for ETSI
Yern
675
338
Good advice for change, I've used less than 1L as top up in 3 years. Much better consumption than my MK3.5 was.
Reactions: KoNG
BoomerBoom
770
281
That's interesting as my last 1.4 engine in a facelifted MK3 used to have quite the drinking problem, but the next two MK4's with 1.5 engines shared the same 1L top up bottle between them.
Reactions: Yern
G.P
1,281
45
Worcestershire
My 1.5 gets topped up with approx. less than a 1/4 L over 8-9000 miles.
Local garage always put Shell or Total in mine of which I top up with as I ask for the can..
Can't help it but the lawn mower also gets Shell..
SuperV8
1,742
844
That oil is not "approved" to the VW 508 specification.
Their technical data sheet just says performance level 508.
I would only use an oil which says "approved" to 508.
You can find lists for VW approved oils suppliers, which have been approved as 508 specification.
For example from Mobil - they say 'approved' It would be illegal for them to say this if it wasn't approved and matching the VW spec.
There was a court case on the naming convention of engine oils - the outcome was basically oil suppliers can only use 'approved' if it is actually approved by the OEM.
Equivalent to, Matches, Equals, Same Performance etc... are just marketing terms.
