Oil pressure sender
leegt5
232
Does anyone know the location on the standard oil pressure switch on the cupra as I would like to put in a t-piece so I can run my oil pressure gauge.. Also what size is the thread on the standard switch ??
LEE
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
I'll post all my pictures from my recent install shortly (just resizng them) it's not simple to do. You use a blanking plug location but the size of the pressure senders usually means a bracket has to be cut. And if you want to run correct oil temp aswell you'll need to drill your sump bolt out.
Reactions: lofty987
