Robaidh
188
Isle of Skye
Hey guys not posted on here for a while.
Im needing a little guidance I have bought and recived boost,oil temp and oil pressure gauges.
Boost is simple enough. From what I've been told theirs a wee Allen key blanking plate that you can remove and screw in the oil pressure sender thingy or the oil temp one.
My question is if I can only screw one in for example the pressure one where do I fitted the oil temp sensor? Do I need to order a sandwich plate? If so where from and what size ect? Or is their 2 Allen key removable things near the filter?
There is an allen bolt on top of the oil cooler which you can use. Its easier to get a sandwich plate, eBay cheapies will do, I bought a Raid HP one (and Raid HP gauges)
Thanks.
I've been told theirs a Allen bolt near the oil filter is their also one ontop of the oil cooler so that would be 2 in total?
