Oil pressure & oil temp gauges help needed
Robaidh
188
Isle of Skye
Hey guys not posted on here for a while.
Im needing a little guidance I have bought and recived boost,oil temp and oil pressure gauges.
Boost is simple enough. From what I've been told theirs a wee Allen key blanking plate that you can remove and screw in the oil pressure sender thingy or the oil temp one.
My question is if I can only screw one in for example the pressure one where do I fitted the oil temp sensor? Do I need to order a sandwich plate? If so where from and what size ect? Or is their 2 Allen key removable things near the filter?
Robaidh
188
Isle of Skye
There is an allen bolt on top of the oil cooler which you can use. Its easier to get a sandwich plate, eBay cheapies will do, I bought a Raid HP one (and Raid HP gauges)
Thanks.
I've been told theirs a Allen bolt near the oil filter is their also one ontop of the oil cooler so that would be 2 in total?
