Since nobody seems to read the problems Q&A section i might aswell try here
new gearbox got fitted a couple of days ago.. all was well, drove to work yesterday morning and the oil light started flashing with 3 loud beeps, so i parked my car up at work and presumed the oil was low and topped it up... which didnt actually take very much.. so all was well again, drove home from work, no problems then went out again later and low and behold no warnings after 15 miles... an hour or so later travelling a short distance.. its back on again flashing and beeping constantly although this time the engines started to sound tappy like it would if it was running without any oil
so far the only things i can presume that could be the problem are
oil pressure (i.e. a block on the system or a leak, but there is no obvious leaks and the oil hasnt dropped after being left overnight)
oil pump (oils not circulating to the camhead/tappets etc)
other than that im stumped.. so looks like im going to have to put it into the VW/Audi garage and spend more money....
