Oil light flashing
knotty
Pocket Rocket
Oct 9, 2007
118
Shotts, Scotland
Since nobody seems to read the problems Q&A section i might aswell try here
new gearbox got fitted a couple of days ago.. all was well, drove to work yesterday morning and the oil light started flashing with 3 loud beeps, so i parked my car up at work and presumed the oil was low and topped it up... which didnt actually take very much.. so all was well again, drove home from work, no problems then went out again later and low and behold no warnings after 15 miles... an hour or so later travelling a short distance.. its back on again flashing and beeping constantly although this time the engines started to sound tappy like it would if it was running without any oil
so far the only things i can presume that could be the problem are
oil pressure (i.e. a block on the system or a leak, but there is no obvious leaks and the oil hasnt dropped after being left overnight)
oil pump (oils not circulating to the camhead/tappets etc)
other than that im stumped.. so looks like im going to have to put it into the VW/Audi garage and spend more money....
jivejester
336
Check the pressure sensor is actually plugged in? If you've had the box off its not impossible it was unplugged. Looked at the top of the oil filter housing on the right hand side, small plug with a single thin wire.
knotty
Pocket Rocket
Oct 9, 2007
118
Shotts, Scotland
would that being loose actually stop oil from reaching the top half of the engine to give it the noisy tappet effect?
VAGcom showed no errors in relation to any sensors.
knotty
Pocket Rocket
Oct 9, 2007
118
Shotts, Scotland
well garage phoned saying they reckon the oil strainer is most likely blocked... but only time will tell...
there quoting £435 for an oil pump?!?!
Big_A_Cupra20vt
184
margate
i had a new oil pump fitted last year for £150 so id shop around if i was you, that was due to a blocked strainer. i wouldnt be paying the kind of money youve been quoted.
Big_A_Cupra20vt
184
margate
also is the red light that beeps on the small while diall top left? as mine beeps and flashes due to a faulty coolant sensor need to change the coolant tank i think and they are about £15 last time i checked.
knotty
Pocket Rocket
Oct 9, 2007
118
Shotts, Scotland
yea it was the oil light with the oil lamp symbol not the red light beside the water temp.
i have been quoted £85 for an oil pump from eurocarparts but would still need to get it fitted, if they say the pumps gone ill go buy the pump and drop it into them cos theres no way im paying 400+ for something just as good
danielc16
cupra R dan
May 13, 2008
327
guildford
i know its been a year but: knotty mine doing the same, and i just had a new clutch and flywheel did u ever sort urs out????
May 25, 2008
2,400
cambs
its prob the oil pick up pipe aka strainer blocked causing low oil pressure,mine did the same a few months back £45 from the dealer easy to replace just messy!
