Odometer reset ?
tronads
7
I thought I would take a look through my vehicle data screens today to see how many miles I have done in my Leon FR ACT150 to date ("all time"). I expected it to be getting on 2000 miles, but was rather surprised to see it reading 281 miles. Looking at the other data, it tells me its done 480 miles since last fill up, which should be impossible given the first figure.
I'm not sure what to do about it, if anything. I guess I will just keep an eye on it to see if it does it again....
Anyone else had this happen ?
concerned cat
497
Huddersfield UK
It resets itself at 99.59 hours.
Julian1977
174
The long-term one does reset automatically on mine from time to time. I reset it manually at the beginning of each month anyway.
Seastormer
Cupra Leon VZ2 300/CBF1000
Apr 25, 2014
5,330
853
69
Edinburgh (Scotland)
The long term on my Cupra resets itself at about 2000m, the last fuel resets when you refill, and the journey one resets itself after two hours of being parked. So you could have done 480 since fuel and the long term has just started again and reached 281, simples.:whistle:
tronads
7
This isn't the trip clock, its the odometer....or at least I thought it was !
Is there some other screen showing the overall milage since birth ?
Seastormer
Apr 25, 2014
5,330
853
69
The odometer showing the total dist only shows when the car is stopped with ignition still on, at the bottom left of the wee screen between the speedo and rev counter.
Obee72
210
Yes !!
Its not the odometer but the 'Long Term' readings in the MFD. Mine reset earlier this week whilst I was driving I believe but I didn't notice until a few hundred miles later. Very annoying when I was keeping an eye on long term.
Julian1977
174
You will see the total mileage if you move the cruise control on OFF. I had the same issue when I bought the car. I had a greyed mph in that place.
Obee72
210
Mine shows when the car is running as long as ACC is switched off. ACC uses the same part of the screen for its display.
tronads
7
Ahh, I always use cruise control. I will take another look next time i go out. Cheers all.
guari
295
I found out the odometer after 3 months of having the cruise control pin to the ON position.
I almost went to the dealer to complain that the car didn't have an odometer. Turn the pin to off.
