OBDEleven Door Card Indicators
jacko5
187
35
61
UK
Cheers.
No worries.
Its just when right hand indicating ( drivers side ) it does not make both door cards flash at all.
They both just go to white from red and do not flash.
Deleted member 103408
Just looked at the file and it does not have a full backup in it.
Can you give it another go with a backup and just double check you have Leuchte16BLK SLB35BLK SL KC9 included in the file.
Reactions: jacko5
jacko5
187
35
61
UK
Opps sorry.
This should be ok.
Thanks.
  • history(1).txt
No problem,
Difference between the two
Dimmwert AB 16 (and the 17) You have 127 I have 100 - can’t see that makes a difference as yours is brighter than mine
Lichtfunktion E 16: you have Blinken links aktiv (beide Phasen) I have Blinken rechts aktiv (beide Phasen) - i think this is your problem change that and see how it goes.
Reactions: jacko5
