non intercooled
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
not a seat so apologies in advance read on you'll understand - i hope
normal turbo cars come with a puny intercooler to say the least and when tuned up a bit we could all agree a decent FMIC is the way to go to counteract higher inlet temperatures but thats on a car with the turbo hidden by the bulkhead in a closed engine bay running high boost
so if we say you had a turbo that was in a fully open engine bay free to the air with no bonnet would you actually need an intercooler ?? and i mean fully open like this
i have heard of it done and when upgraded to larger turbo's and boost levels they have added water injection
having drawn out all the manifolds etc and plans i suddenly thought do i really need an intercooler ????
what do ya reckon
LNeves
Orangina
Feb 7, 2005
201
An IC will provide a wider area for heat transfer, so I presume that an IC will have it's benefits on any turbo engine. But I think you can only use WI to lower intake temps.
The fully open engine bay only would let the air cool down the turbo itself, and the intake pipe/mani. Not so sure about heat transfer eficiency compared to IC.
Then again, in drag racing, is it worth to get an IC for the 1/4 mile run ?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
what level of boost (compression?)-not much then not much compression so less heat.
WI can deal with a level of induction temp.
eg.. my current >2bar boost level blisters the silver ally paint off my pre-intercooler pipework!
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
Iwould have thought so, more related to compression than turbo heat transfer
1.5 bar tops to start at the max really as pistons are a bit of a bug bear to get right now and will have to be made or modified - so gently does it
but it will be a daily road driver not a drag stripper - cant have a v8 twin turbo and not take it to work every day can ya ?:rolleyes:
measured up the grill and radiator and looks like i have enough room for a std ibiza size IC so ill use that or similar anyway and with open bay should help especially as its mainly grunt - not exactly a revving screamer
john banks
105
UK
You can run without an intercooler on pump fuel and sensible compression ratios at say 5 PSI. With a big V8 this could work nicely.
If you run it off methanol, you can run big boost without an intercooler.
If packaging is tricky, consider a water:air rather than air:air intercooler.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
was considering water injection as a back up if temps started to rocket as i turn it up
methanol ? lol would love too but shell dont do it yet and the MOT guy would probably faint
packaging is no problem - as long as it looks good [B)]
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
but it will be a daily road driver not a drag stripper - cant have a v8 twin turbo and not go to work every day can ya ?:rolleyes:
if 1.5bar then you will deffo want some intercooling m8
WI with water/meth mix will combat some of it, but I cant see it coping tbh
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
found a nice spot in the grille for a cooler so plan B in action and will be cooled anyway now
as a bonus for the first running with just the injection (megasquirt non turbo) its as good as a tunnel ram too :)
Ibiza Cupra
Call me a pr*ck if i've read wrong but... a daily drive with no bonnet?????? Are you serious???
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
I also think that fitting an IC is way simpler than WI [???]
Then, now that I think about it,,, what ya workin on daz?
must admit agree there - plan is clean simple and hidden even with injection and coil packs (few tricks up my sleeve) so the less wiring and sensors etc the better really - and safer with an IC for sure and i've found a good way to hide it from obvious view and will be approx room for one about 1.5 times the size of a std ibiza 3 with option for larger - but then it is technically 2x 2.0litres so may just add a laguna type FMIC in front of the rad to overkill for options later
lol i promise i wont say it - yes a daily driver (more or less) i believe in driving cars not trailers and show queens and yes no bonnet and yes no sides too - open engine bay imagine a mix of these 2 but gunmetal and red and fatter tyres
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
cold air from front straight to the filter - is that a scooby i guess ?
running 8 injectors too or is that giggle gas ?
the turbo/pipe coated like this would just finish it off :)
i do like a well thought out tidy engine bay - respect
chungster
SCN Veteran
May 27, 2001
688
Bedfordshire, UK
It is indeed Andy Forrest's Scooby.
9.3 sec 1/4 mile now.
Think he is aiming to break into the 8's at the Pod this weekend (Japshow Finale)
8 injectors + 50bhp NOS I think he has. Maybe he didn't have it plumbed in on the day of that pic.
Ibiza Cupra
Yeah rite, wot's the point in having a car you can't drive, but how is this legal???? I thought things like side exit exhausts are illegal in this country????
So an open engine can't be too legal???
Ibiza Cupra
Wish i could of made it to the pod. I was seriously disappointed with USC this event looked wicked.
