yea i wer gunna say the same just rang um,,,,,,,hu i orderd a piller wednesday night just wanted 2 c if it is on the way,,,,,,,,,,,du recon they wer on shutdown then,,,,,,, i wanted to fit it 2mora
you'll need a small round file to enlargen the screw holes, and possible the gauge fitment circle. I had to file the screw section (where the grab handle caps are) quite a bit, but worth it as it fits nicely now.
May also be worth using some stickyback velcro, to secure the middle section, is secure.
fitting is simple, remove grab handle (remove 2 screws) A piller then comes off with a little pull
replace with nomad, fit gauges (different setup depending on gauges), apply alot of velcro on the inside of the A piller (from nomad) and also on the A Piller itself, screw 2 screws back into grab handle
