Noises
becks7
Hi, has anybody experienced persistant noises coming from somewhere in the back of the car (internally)? I really cannot handle them, and cannot find the source. I also need an advice since my front seats squeek everytime somebody sits. It's the back rather that squeeks. What can I do? Do i have to replace the seats??? It's driving me mad...
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
Yeah I get noises coming from the back of the car, have you tried making sure the spare wheel is properly screwed into the wheel well as this causes noise when going over bumps, mine was loose and it was driving me crazy.
Oct 17, 2006
2,141
Mid Wales
Its often the rear seat locking mechanism - your stealer can adjust them for you or i'm sure you could do it yourself if you're technically minded ;)
becks7
Well, I 'll try doing the spare wheel however since I have never used it I have my doubts that it is the problem. I strongly suspect it's from the back seat, or the boot door.
However, my biggest problem is that my two front seats squeak whenever somebody moves his back a bit. That's really something I cannot tollerate. It's getting me really angry[:@]
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
to stop the front seats from squeeking try pulling the covers off both sides of the seat and spraying some white grease on the mechanisms and then wind the seat back rest backwards and forward to work it into the gaps.
the noise from the rear would as the other guys said either be rear bottom half of backseats not clipped in propley or spare whee screw cap lose, maybe check the parcle shelf if none of theml could be woth getting some 1 to check over your suspention? :shrug:
becks7
I'll give all these a try soon. But how can I remove my front seat covers? I did not put any additional covring to the seats. Or you mean I must remove the original covers?
Thanks a lot!
rashcupra
Oct 15, 2006
6,517
crawley
Thanks a lot!
you need to remove the covers from sides of seats just unclips off try not to use wd40 because wd40 thinnens lubricants and drys out and will probably make it worse
