noise off turbo when revving up
danielrobertc12
can some one help us ive got a ibiza turbo and when i rev it up theres a whistling noise off the turbo some where any ideas,some one said it could be the actuator
WeeJase
pert
Jun 2, 2001
8,595
the turbo itself whistles mate.if its not a nice steady whistle or fluctuates when your on the gas then you may have a leak some where.but thats what turbos do,its a turbine,spinning at fook knows what rpm ;)
danielrobertc12
im aware turbos whistles ive had **** loads in the past, but the noise is like its ttto much for the speed its going if you know what i mean could some one reply at least if they know something about these cars thanks
WeeJase
pert
Jun 2, 2001
8,595
what cars have you had and can compare it too?the ibiza has a fairly small turbo and runs a smallish amount of boost as standard,this gives it very little lag(2k rpm iirc). its hard to describe i know but a bit more info would help.
not all of us are taking the piss btw ;)
NeilC
Has left the fold...
Mar 23, 2004
336
somewhere else
Is the car remapped?
Does it only happen if you floor it from low revs? Try 3-3.5k on.
I'm thinking it's cavitation 'harmonic resonance caused by the air flow being disrupted. This is happening due to a lack of volumetric effeciency either on the compressor side or the turbine side of the turbo, as we know these turbos are limited by the intake and outlet to and from them'
Is it a screeching type sound?
Changed/ serviced dv?
Dunno much about ibiza's, just giving you ideas.
MR Ibiza Cupra
185
London
Whats the mileage on the car ??? or even....... how much mileage has that turbo done !!! do you know - as turbo come towards the end of there life they gegin to get a bit louder.
danielrobertc12
its more like a high pitch noise like its over boosting ,what could cause that
