Hi guys, I have been posting in the what have you done... thread but thought I would try keep it all separate so it doesnt all get lost with other posts.
so the bottom line is I changed the timing belt kit for a Gates kit and I had a noise when it went back together, sounds like a drumming/vibration type noise coming from the middle of the area around the waterpump or tensioner setup. I took off the AUX belt to rule out all of that side and the noise was still there, then I tried removing the bottom and middle timing belt covers and although the noise was quieter it was still there (I think the cover make it echo more). So failing to find where the noise was coming from I ordered Febi kit and replaced it all again and the same noise in the same position is still there. this video although it isnt my car sounds exactly the same....
I cannot think that I have been so unlucky that both kits are faulty and theres no manual adjustment in the tensioner setup its just pull the grenade pin and go so does anyone have any ideas?
