Noise after Timing belt replacement x2
ExiledWeegie
23
Hi guys, I have been posting in the what have you done... thread but thought I would try keep it all separate so it doesnt all get lost with other posts.
so the bottom line is I changed the timing belt kit for a Gates kit and I had a noise when it went back together, sounds like a drumming/vibration type noise coming from the middle of the area around the waterpump or tensioner setup. I took off the AUX belt to rule out all of that side and the noise was still there, then I tried removing the bottom and middle timing belt covers and although the noise was quieter it was still there (I think the cover make it echo more). So failing to find where the noise was coming from I ordered Febi kit and replaced it all again and the same noise in the same position is still there. this video although it isnt my car sounds exactly the same....
I cannot think that I have been so unlucky that both kits are faulty and theres no manual adjustment in the tensioner setup its just pull the grenade pin and go so does anyone have any ideas?
Battoussai
463
127
Portugal
Do you have the old tensioner and pulley? Would you be willing to give it a shot at installing the old tensioner just to rule it out? Maybe you can try and record sound only with your mobile getting close to each one of the pulleys to try and find out where the sound is louder and locating the origin?
Have you rule out the alternator?
Reactions: ExiledWeegie
ExiledWeegie
23
yeah ive still got the old pulley, tensioner, belt and waterpump, all audi stamped parts and it was done at a seat dealership in wolverhamptom. and yeah ruled out alternator, its only 1 month old but ive had the aux belt off and ran the engine so the noise isnt coming from anything in the aux belt setup.
ive done around 150 miles on the new febi kit and although the noise is still there the car runs fine so im in two mind wether to try taking everything apart again or just leaving it and see how it goes, the video above were the guy comments that its calmed down after a while gives me some confidence that its a bedding in thing but any other timing belt ive done on other cars didnt have noises afterwards, its a catch 22 situation and to have the same noise with 2 different kits...hmmmm annoying
ExiledWeegie
23
And all is tighten to standard correct torque? That's a odd one.
yep all torqued to factory specs.
Ive now done around 400 miles and the noise is still there but cars driving perfectly and you cant hear it from inside or from different places around the car, only from the drivers side wheel arch area, but I think I'm now in tune to the noise so its the only thing I can hear lol
Battoussai
463
127
Portugal
I know how its like when we got that weird sound in our head and it doesn't go away. :)
I would take the bottom rock cover out and would try to see if anything is loose or tumbling around from down there (with engine running on idle).
ExiledWeegie
23
I already had it running with no covers on it and the noise is still there.
I think that the belt is too tight on the waterpump side, when I put it all together it was a struggle to get the belt over the pump pulley, I think I should have tried to have it all on the waterpump side first and then slip it onto the tensioner side.
I dont know wether to try tackle the job again or not tbh.
Battoussai
463
127
Portugal
You sorted it the long way. My mech was done the belt all over the pulley's path and for last the tensioner. Maybe you could try just to ease the tensioner a bit to see if it releases any pression or corrects the path towards the pulleys ahead.
