Been having a DPF light coming on for a while now, tried regenerating during driving and it improved for a short time then quickly disimproved again to the point now if i drive above 2k revs, it goes into limp mode and drives like an old lada (SLOWWWWWWWWW)
Took it into the garage the other day cause it was showing me an engine light and wanted to talk to them about the DPF issue, they scanned the car and got a turbo pressure issue.
So reset the codes, took it for a drive and read codes again.
No DPF code showing up
Just a turbo pressure code.
He took the vac line off the turbo, but the engine note didnt change (is this a thing) but the actuator seems to be activating all right.
He was suggesting the actuator might be broken inside the turbo meaning i would need a new (replacement) turbo?
Now heres the question, what other cause would there be that theres no DPF code showing up.... cause i know the dpf light is coming on while on the motorway / longer drive.
What else would cause the turbo code to come up like that?
Also if it helps, when ya start the engine. Unless you have the air recirculating, you get choked with exhaust fumes......
Ive had this car at 3 different garages, One told me there was nothing wrong with the car (Main Dealer) one told me to drop the DPF and clean it out, and the third has told me to replace the turbo.
Kinda at a loss for what to do, I dont mind dropping the DPF and Cleaning it. Dont mind changing the turbo, but could realllllllly do without the expense.
Suggestions or experience would be helpful
