stevie16v
99
Just got my car back today after it having spent 2 weeks in the garage with bad brakes. Turned out to be the master cylinder. Thats now been replaced. However, now i have no traction control of abs. I have "tried" both of them and they ain't kicking in at all. Any suggestions?
no they aren't on. I can turn the tcs on and off with the switch tho so doesnt appear to be a fuse
How would a coil pack cause that?
Ive been having a wee look about, is it possible that the abs pump maybe just needs bleeding? it def wasnt done as the garage it was in at doesnt have diagnostic equipment
its a coilpack mate
No its not, go home and stop giving stupid advice!
It'll more than likely be the hub speed sensor, bout 60quid for the part and its a diy job, just on the inside of the hub behind the disc, give it a little clean and see if this helps, its just where the strut and the disc sit at there closest.
