No ABS or TC!
stevie16v
99
Just got my car back today after it having spent 2 weeks in the garage with bad brakes. Turned out to be the master cylinder. Thats now been replaced. However, now i have no traction control of abs. I have "tried" both of them and they ain't kicking in at all. Any suggestions?
stevie16v
99
no they aren't on. I can turn the tcs on and off with the switch tho so doesnt appear to be a fuse
stevie16v
99
How would a coil pack cause that?
Ive been having a wee look about, is it possible that the abs pump maybe just needs bleeding? it def wasnt done as the garage it was in at doesnt have diagnostic equipment
BCM
Keyboard Gangster
Feb 1, 2005
2,680
Wishaw, North Lanarkshire
its a coilpack mate
No its not, go home and stop giving stupid advice!
It'll more than likely be the hub speed sensor, bout 60quid for the part and its a diy job, just on the inside of the hub behind the disc, give it a little clean and see if this helps, its just where the strut and the disc sit at there closest.
