Do bear in mind that a cat back exhaust will offer absolutely nothing in terms of performance. The standard exhaust is good for a lot more power than you'll be running with, so I'd drop that right down the list. The only reason to buy a cat back exhaust is for cosmetics.... i.e. the look and sound. And since the LCR already has a good looking exhaust, you're buying a sound.
Spending the money on anti roll bars, a dogbone mount and a short shifter will make much, much more of a positive difference than a cat back exhaust.
The ARB's will help keep your car on the road and will help make the most of the power you have.
The dogbone will reduce wheelspin and wheelhop when you plant it in lower gears.
The short shifter will give a very nice, positive gear change and will help you rattle through the gears quicker.
A cat back exhaust will make your car sound a bit deeper and louder. That's it.
