Next MOD to get ?!
What Mod to do bext
  • Clutch - VR6/G60 Combo or SPEC clutch £350 ish
    Votes: 4 10.5%
  • AP Coilovers £380
    Votes: 23 60.5%
  • New Brake Setup, Brembo Grooved Discs and Ferdod Pads £300 ish
    Votes: 11 28.9%
  • Total voters
    38
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
lol....i think you should start up a cheap coillie thread up here....:cartman: ;)
searching a few forums for a brake upgrade. Im really 50/50 on brakes and coilovers
Should really go for saftey over looks after going ko3s
warren_cox
Back from the dead
The informed choice
30-50mm drop. What's not to like. You will obviously end up as a social lepper but you will have the last laugh tanning the ar$e off people who have shyte cheap coilover set ups!
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Have been looking at the Weitecs, so you think this is a better setup than the AP's (made by KW same as Weitec) that are a full coilover set and about 50quid more?
warren_cox
Back from the dead
Spring / damper set up: Once set up, always 100% until worn. Less adjustment = less to go wrong. Probably will last longer. Won't corrode and then seize like many cheap and unmaintained coilovers will do.
Fact more moving parts generally = more maintenance required.
If they can give you coilovers for the price of spring/damper set up I would be deeply concerned about long term build and reliability. Where's the catch?!?!?!
Manufacturers can make this kit dirt cheap, but they quality standards of manufacture may be lower, the materials less well / rigourously tested. Just because it is owned by KW doesn't mean KW factory ever sees it, and its probably made under license by crack wh0res in a favella in brazil or something ;-)
I am to the spring/damper combination what Hugh Fearnley Whittingstall is to free range chicken!!!
It's your car mate so you choose away, but I wouldn't buy coilovers that cost less than a grand to supply and fit - period, and that was if I could justify the need.
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Class, havent seen Waynes in the flesh yet, but from a few pics it does look very nice, how much did you pay for the AP's Sooty? I put a message up in the Meets section to see when the next Kingson VAG meet is...let me know mate.
Looks like im going to end up getting a set of Audi TT 312mm brakes with Ferodo DS2500 pads for a very good price! Coilovers can wait for the moment!
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Found a second hand setup off another forum. Look in good nick and they were on a mk3 before of all the modifications have been done to them to just bolt them straight on....fingers crossed!
Callipers do need painting though, they are just black and 'orrible from the pics
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
lol....that can wait, standard brakes are shi*e as we all know and a snip at 200squid. Coilovers will be next in line though for sure, then clutch when it starts slipping
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Quick update, brakes won the day, just completed my purchase for the Audi TT front brake setup. Comes with the callipers (need to paint red), discs, braided TT lines and a brand new set of Ferodo ds2500 pads! Got the lot for 220quid including delivery. Good price i think as the discs have had less than 1000miles on them and are already drilled to 4stud fitment and the pads are still in their box!
Will post pics when they arrive :D
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Thinking of a set of Weitec springs and dampers with a fixed drop. Not all that expensive, around the 300quid mark. Will have to wait until im back from my trip to Japan then get things moving again if i have any cash left! Will probably get spacers done at the same time. Ibiza's look great when lowered!
