New to VagCom... First Logs
blackie
I'm Tyrannosaurus Alan!!!
This is the first time i have logged My ibiza cupra, totally standard other than a uprated recirc valve and a remap to 191.8 bhp...
Do the mass flow reading give an indication as to the MAF and how it is functioning??
If so does my maf look ok after these logs in 3rd and 4th?
And ideally what sort of figures should i be looking at??
RPM Mass Flow Load Ign. Timing
TIME
STAMP /min g/s % °ATDC
0.8 1360 2.92 1.6 0
2 1360 6.19 4.7 28.5
3.2 1480 19.44 21.6 17.3
4.4 1720 27.75 100 12
5.6 2040 38.08 100 9.8
6.8 2400 42.11 100 13.5
8 2720 50.14 100 15
9.18 3120 59.44 100 16.5
10.38 3480 63.56 100 17.3
11.59 3880 68.39 100 18.8
12.89 4240 77.14 100 19.5
14.09 4600 83.28 100 19.5
15.29 4960 88.94 100 20.3
16.6 5280 92.78 100 20.3
17.9 612 -293.37 200 140 025 Map 1
27.49 5480 11.31 5.9 15
28.69 5320 11.11 8.2 15
30.08 5000 10.5 7.8 14.3
31.28 4640 10.03 7.1 13.5
32.48 4360 9.08 6.7 12.8
33.68 4080 8.25 6.3 12.8
34.88 3760 7.69 5.9 12.8
36.08 3440 7.06 5.5 12.8
37.26 3120 6.39 4.7 13.5
38.48 2720 5.56 4.3 12.8
69.86 2640 40.75 31.8 22.5
71.06 3480 65.08 100 18
72.26 4360 79.72 100 19.5
73.46 5240 92.44 100 20.3
74.66 6000 101.92 100 21.8
84.45 4960 87.36 100 21
85.65 5120 71.42 98.4 5.3
86.85 4920 9.44 7.1 14.3
88.05 4680 9.36 7.1 13.5
89.44 4480 9.33 6.7 13.5
90.74 4240 8.58 6.7 13.5
91.95 4040 7.94 6.3 13.5
93.14 3720 7.56 5.9 12.8
94.35 3320 6.58 5.1 13.5
-pseudonymous-
681
Looks like your MAF is shot. A standard cupra should read around 125g/s, when re-mapped you should be seeing around the 155g/s mark. Would be easier to read if you did a single run from 2000 rpm to redline without letting off at all. Your peak air flow will be right at the top of the rev range.
