New here, mod help
Nov 14, 2019
Hi there,
Let me introduce myself first I'm lewis hi,
I have owned alot of VWs a couple of 1.8t not done much due to my age.
Last month I decided to buy a leon cupra mk1 2004 auq 180bhp
Two days into ownership white smoke and turbo failure ouch right,
Turbo changed for recon turbo
Having a few boost leak issues and car seems to be running slow every now and again.
Anyway I'm looking to put some power through it would like some suggestions,
Current thoughts.
008 reserc
Fmic
Sia delete
N75
N249 delete
Exhaust maybe sport cat back
New manifold ordered as mine was cracked noticed when changing my turbo.
Car already has the full exterior r conversion bumpers side skirts.
Any help with issues that I've raised and possible things I should do to prolong the life of my car and power please let me know.
Many thanks
Lewis
bigT's lcr
Delete. Beat. Repeat...
Feb 27, 2016
1,216
732
Leeds
Hi there,
Current thoughts.
008 reserc
Fmic
Sia delete
N75
N249 delete
Many thanks
Lewis
Hello and welcome. Have you looked into the TIP? the originals can flatten under negative pressure. As for the boost leak replace all the boost pipes with silicone. You'll be getting rid of alot with the n249 and sai.
Nov 14, 2019
Have looked at maybe oversizing after market TIP, and hopefully I'll be bypassing most of that in the morning, yeah was gonna buy all new boost pipes but realised they normally come with the fmic kit so gonna hold if till pay day, yeah would make sense if it is the tip as I drove it to work earlier 31 mpg so nice and slowly, then on the way home tried to give it a blip no obvious boost leak noises but felt like it was revving slowly and not getting up to speed, for example I normally get 60 in second top wnd I was getting 40 max but turbo was almost silent, how would I check if it's the tip ?? Many thanks
bigT's lcr
Feb 27, 2016
1,216
732
Leeds
Could be a dodgy turbo or maybe tips collapsing and smothering it. Just grab it. If its really easy to squash and is quite malleable then replace it with the reinforced silicone one.
Nov 14, 2019
I'll have a look tomorrow and let you know, many thanks and any change there is a place to put build threads on here ?
Nov 14, 2019
Update
Turns out my lower side mount pipe popped off slightly giving a false reading to my map sensor,
Clamped down hard now
Many thanks
