Needle sweep
ceb
121
Lebanon
I did a small search up the forum, apparently you need access to VAG-COM and enable staging under instruments.
kw1984
138
Manchester
I think the computer side of things has the ability to sweep as the Torque app for android sweeps when the ignition is turned on. Just the dials in the car don't seem to recognize it.
Ahl
51
Just to drag up this old chestnut again...
I take it this is a MK4 Ibiza Cupra? :(
Ibiza Cupra needle sweep:
youtube.com/watch?v=tS-hmN8f2_U
There is also a guy on the Polo forum enabling the indicator sweep for polo/golf instrument clusters that can't normally do it:
tigerstyle.co.uk/phpBB3/viewtopic.php?f=56&t=52403&start=15
youtube.com/watch?v=FyfbyCMFoyA
Ahl
51
Actually, that needle sweep appears to be on a 2013 Ibiza Cupra.
More info here: (Turkish seat forum, need to translate)
seatclubturkey.com/seat-arac-videolari/42685-2013-cupra-welcome-mode.html&prev=/search%3Fq%3Dcupra%2Bwelcome%2Bmode%26start%3D10%26client%3Dfirefox-a%26hs%3DvKV%26sa%3DN%26rls%3Dorg.mozilla:en-GB:eek:fficial%26channel%3Dfflb%26biw%3D1024%26bih%3D627
So the question is, does this work only on 2013 Cupras, on Turkish ibizas, or does it just need the latest version of 12.12 Vagcom to enable the adaption channel?
"17-Instruments -> 10-Adaptation -> Channel -> indicator_celebration -> active"
Ahl
51
Ack, unfortunately Vagcom 12.12 didn't allow this to work on mine, so must just be certain new models.
Worth a go though if you have a pretty recent model.
