need to active speed limiter
Jul 29, 2021
25
So what is the correct syntax?
1- Control Unit : 17 Dashboard
adaptation: Display of longitudinal regulation coordinator:
Speed limiter: Active (default : not active )
2- Control Unit : Engine 01
long coding
byte 6
Feb 11, 2022
long coding
byte 6
Hello dear
I had static error u111000 in dashboard since I used the one touch app
Also, I’ve noticed that some items in service menu are missing, such as oil temp & energy consumers.
Could it be because of the engine long coding done by the app?
If you have the same case please let me know to revert the long coding, if not, appreciate if you share your backup with me to compare
my Tarraco is excellence 2021 from Egypt as well.
Thank you very much for your time
Nov 21, 2021
30
Hello dear
Contact me if you want to checkup
