Been aving problems with my brakes for last week, grinding coming from left side, so thought pads must be low. Bought new pads and disks fitted them n noise still happened, though they might need bedding in. I though it was front brake as it made noise when I braked, but does it brake 4 wheels with foot brake? Anyway my back rear brake disk has snapped in half due to pads failing and piston pushing on disk, the piston is pointing upwards now and brake fluid is leaking out. So new disk, new pads and new calliper is this a hard job? I could do the disk and pads but not sure about the calliper with fitting the brake lines how do I do this? Do the front and back brakes run off same fluid?
Thanks for any help
Thanks for any help
