Need help asap (Window is stuck down)
micallef
66
Orite everybody had a little problem tonight, window has stayed stuck down on my driver side and when i try put it up it just makes a horrible sound, anyone know what this could be would it be my window regulator or something else? anyone know whats needed to get the door car off as i dont have any tools in my house apart from a saw and a door stopper.
help is appreciated thanks ben
micallef
66
Indeed who is a good place that will have them in stock? Somewhere like euro car parts?
micallef
66
Thanks for link pal. Only thing is cat isn't garaged and don't want to leave it any longer than I can with a bin bag covering it. So need to find somewhere who will have them tommrow
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Try euro car parts about £45 mine was and it's a hit job allow a good few hours easily, maybe more if your not "technically minded"
Fozzy84
252
137
Common fault on mk4 golfs, relatively easy to fix.. As the inner plate has the runner for the window connected to it (well, it does on the golf)
micallef
66
Just called euro car parts they don't have the regulator fixing kit just the regulator at around 40 pounds so going to get that this afternoon hopefully it should be that
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
No need take the glass out hold it up with strong tape when you undo the 2 x 10 mm nuts
Leave the door lock alone push the plastic studs through (highlighted by the red arrows) then retrieve them when the panel is removed
removing the old one needs the rivets drilling out and i had to enlarge the holes as the bolts wouldn't fit through on the regulator
Getting to the power for the lock you need an extra pair of hands to disconnect it
get some butyl sealant on a roll to reseal the door again.
micallef
66
I was also getting some water in my footwell would sealing it back up stop the leak from happening?
micallef
66
I think it was coming from the door card. Should halfords sell all the bits I need? Might just do it down there as will be allowed to use the tools
micallef
66
Trying to do it now got the door card off. My problem is my window is fully down so I can't get to the bolts to release the glass . How can I get the glass out?
micallef
66
I have tried the window is all the way down and it's solid at the bottom so I can not grab the glass and I don't want it to break
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Loosen the bolts around the metal panel leaving two in the top, and remove the rest might be able to get your hand in then to help it up
