N75 Valve Location
gavos
Hi,
Where can i find the N75 boost contol valve on a GOLF PD 150
Slugger
Hey sorry to hi-jack thread. But where is the N75 and N18 valves on a seat leon, 1.9 TDI 110. Its a 2002.
Any help really appreciated!!
Slugger
There seem to be two identical ones? Is it one of those? They are attached to the firewall bit right at the back and are towards the right but not as far over as the MAF sensor
Thanks!!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Okay, heres an annotated underbonnet view of a TDI 110 that I have used in several threads now (although it isn't original to me, and I can't remember who I copied it from now).
For completeness, I should add that the sensor assembly in the pipe from the intercooler at 12, labelled IAT (Inlet air temperature) also houses the MAP (manifold air pressure) sensor (NOT to be confused with the MAF - Manifold air Flow sensor, which is labelled 4) This makes sense, as you want to know the temperature and pressure of the charge going to the cylinders, after the intercooler.
I don't think the colour of the vacuum switch elements is a reliable indicator of their function, as there is no difference between the two in what they do, just that one is connected to the EGR and the other to the turbocharger inlet vane control.
Slugger
Thats fantastic! I have been searching for ages looking for something like that but couldn't find it for the life of me!
So I assume the N75 and N18 are not identical in what they do so you need to make sure you buy both if you wanted to replace both?
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Well, both look the same and perform the same basic task, pneumatic switching. Two pneumatic "fixed" inputs, atmospheric pressure (from the airbox) and vacuum (from the vacuum pump and reservoir), one output, taking a variable pressure to the actuator. Each has an electrical input from the ECU which works the valve to vary the output pressure. They have the same outline, fixing and general shape, so in theory they should be interchangable.
However they have different part numbers, and as ssstew has noted, different colours of cap. I don't know for sure if there are internal differences.
Slugger
Thanks! Trying to sort a problem out whereby the turbo doesn't kick in until 3k revs. But if you then immediately drop down it works from 2k.
I think I might relate to one of these vavlves so going to replace both and see how I get on.
