Well I have just bought a 2004 seat Leon SX 1.6 16v (BCB) last week the engine light has came on, i have plugged it into diagnostics and have quite a few fault codes, had it into my friends garage and we're no nearer to the cause of the problem.
I'm having low/dim lights at low revs, and the power steering cut out on me once at low revs leaving the steering wheel unmovable restarting the car fixed this.
All the Earth's have been checked and a brand new fully charged battery has been installed, but we're still scratching our heads as to what the problem is, anyway the fault codes are as follows, if anyone could offer any advice i would really appreciate it.
3 Faults Found:
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-10 - - - Intermittent
17586 - Linear O2 Sensor: Pump Current: Open Circuit
P1178 - 35-10 - - - Intermittent
17589 - Linear O2 Sensor: Reference Voltage: Open Circuit
P1181 - 35-10 - - - Intermittent
VAG-COM Version: Release 409.1-S
2 Faults Found:
01179 - Incorrect Key Programming
35-00 - -
00928 - Locking Module for Central Locking: Front Driver Side (F220)
27-10 - Implausible Signal - Intermittent
Address 08: Auto HVAC
Controller: 1M0 820 043 E
Coding: 00041
Shop #: WSC 06402
Note: Excessive Comm Errors
Address 15: Airbags
Controller: 1C0 909 605 A
Component: 39 AIRBAG VW51 0A 0008
Coding: 13113
Shop #: WSC 06401
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments
Controller: 1M0 920 902 A
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 04406
Shop #: WSC 00000
VSSZZZ1MZ4R095955 SEZ7Z0D2352771
4 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to B+ - Intermittent
29-10 - Short to Ground - Intermittent
00667 - Ambient Temperature Signal
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06402
1 Fault Found:
3 Faults Found:
2 Faults Found:
35-00 - -
Coding: 00041
Shop #: WSC 06402
Address 15: Airbags
Coding: 13113
Shop #: WSC 06401
1 Fault Found:
Coding: 04406
Shop #: WSC 00000
4 Faults Found:
Coding: 00006
Shop #: WSC 06402
1 Fault Found:
