Vicky M said:James, your lights looked the mutts tonight, but you suffer the same problem i had with LED rears in the Ibiza?
3rd brake light glows with tail lights on???
The problem occurs because there is not enough voltage drop using LED's, therefore a resistor pack is required.
biggest issue i had, was the car was telling the ECU that there were no brake lights, thus dropping power, and flashing the EGR light on the dash board?
Hope yours runs better, i reverted to stock bulbs, coz i couldn't be bothered to work out the resistance required!!!
J@mes said:thanks!
but wats this 3rd brake light glow? mine is fine as far as i know! (did u think mine was glowing?)
tho i know DAN has has the engine managment light come on on his!
Vicky M said:It's down to the resistance across the bulb. LED's draw such a little current that the electronics thinks that no bulb is present/or not working.
I had it when i put LED indicators into the Pug, they just flash mental, as if one bulb has blown.
The only way is to put a resistor pack in line, so the current draw is not measured.
I'd put it back into the hands of RAID. They should have made it clear when you bought them
SoLiDSnK said:James! post pics of the rear lights with sun! . At day, I mean .
