myslilyyli
Hi, been here a long time but now is the time to start my build thread. So here is the specs so far:
Car: 2007 Seat ibiza FR 1.8t yellow
Engine:
ARP head bolts
Head:
Supertech manganese bronze valve guides
Supertech inconel exhaust valves
Supertech intake valves
Supertech titanium valve retainers and springs one groove version
ported small port head
n/a 1.8 camshaft adr engine code
oem valve seals
Bottom end:
Ie 19mm drop in rods
ARP main studs
IE timing belt gear dowel kit
IE arp crank damper bolt
oem pistons
forge baffled sump
gates performance timing belt
manual timing belt tensioner
metal impeller water pump
Turbo
Now Borg Warner EFR 6258, 1.6 bar overboost and 1.4 constant
Drivetrain:
ClutchMasters fx400 6 puck ceramic clutch
Brakes:
6 pot D2 calibers and 330mm 2 piece discs
castrol srf brake fluid
zimmerman drilled discs
rear brakes:
Audi S4 300mm vented disc and tt225 calibers
Suspension:
Seat ibiza cupra mk4 springs and koni fsd dampers
whiteline rear roll-bar
Kw 22mm front anti-roll bar
forge rear and front strut brace
OMP lower front strut brace
Cooling:
External oil cooler Setrab 625
Garrett 600hp IC.
Wheels and tires:
OZ Alleggerita hlt 17x8 wheels
215/45/17 toyo R1R tires
Last dyno was 287,6 hp from engine and 375nm of torque(this was holset he221w turbo).
Engine:
ARP head bolts
Head:
oem valve seals
Bottom end:
ARP main studs
oem pistons
forge baffled sump
Turbo
Drivetrain:
Brakes:
rear brakes:
Suspension:
Cooling:
Garrett 600hp IC.
Wheels and tires:
