My DIY Short Shifter
xd-data-ii
375
San Diego
Hey,
Inspired by this thread http://www.seatcupra.net/forums/showthread.php?t=117350
I decided to try to modify my gear shifter for shorter throw.
Took off the shifter component to find that the original pin cannot be removed and is pressed into the shifter. The guy in the other thread seems to have a modified shifter and none original bolt.
So not to be beaten, I carefully took all the measurements of the orignal pin and basically created my own pin using a lathe to cut it to the correct dimensions and shape and threaded it to catch the nut below the shifter unit.
After determining the position i wanted it to be I drilled a hole in the shifter and tapped it.
Added the new pin, bolted it up and installed it to the car and replaced the cable connector to this.
Works great and feels more like a switch now. Much better. About 40% reduction i think (havent measured).
Can always go back to original too if i want.
See pics below.
Steven
Original Shifter
Original Pin
Hole drilled in Shifter
New created pin
Shifter back on the car
Shifter back on the car 2
lc_allan
Northern Monkey
Sep 15, 2006
3,389
wow nice work, not many people have the skills on here or access to a lathe to modify their own :), you offering a service?, or new pins? ;)
lard44
Watching C beams...
Apr 30, 2007
474
Braintree, Essex
That's very impressive...fancy doing doing mine? LOL!
Wish I had the skill/time/ability/energy etc. etc. to do that - it looks very smart indeed.
Cupraloon
Top Work Fella,
I think you might be in great demand on here now for this little job.
Don't suppose you fancy producing a few, and flogging them, do you.
LCR User
Stage...
Jan 17, 2006
57
Def would take one too!
Would save me 80 squid and you make it look so easy! No engineering skills here but worth a shot...
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
and then you're into a whole grey area of having no PLI should it go wrong.
It won't be publicised on this site, that's for sure
Punch IT!
you fool!
Jun 22, 2007
396
west london
Yeah good work, But the car is not cheap so why cheapen it now with DIY Mods? Surely the odd £70 here and there can be justified especially on top quality mods about. i just ordered the short shifter last nite cant wait more speedy gear changes here i come from no other than forge.
