My Cars Dead! lol
Nov 2, 2004
9,335
South Wales
Typical after spending an entire weekend on it and everything working well and it running really well for the first time in ages the bloody thing just cuts out on me about half a mile from home.
Wont start just cranks over and over.
No fault codes, no lights on the dash, battery voltage fine.
My thoughts are suspected dead fuel pump. Great.
warren_cox
Back from the dead
What a $h1tter.
Fuel filter OK? Can you hear the pump priming?
Nov 2, 2004
9,335
South Wales
Filled up on monday, about 3/4 of petrol in it on the gauge so i dont think its that.
Pump was swapped for a 4bar S3 pump which i intend to remove after i check the pump is priming/sending fuel through. Any quick tests?
Ill check the fuses as well.
Nov 2, 2004
9,335
South Wales
It runs. Via a paper clip. Ghetto tuning at its best. lmao.
Something is up with either the WOT BOX or the earth or feed to it as its not powering up properly.
Ive reconnected the loop to the coil packs, as that was the problem, no spark, and it starts with no problems.
Happy days. :)
