Mike i cant believe you took the whole bumper off to do the HIDs...imagine if one of them fails what hassle you will have to go through?
It does look good tho!
Took Bumper off as I took the lights out again. Re-sealed the left one, adn I had nothing better to do
Plus I've done it so I can change the bulbs easily enough if I have to. The ballasts shouldn't fail.. if they do its another 80 minutes of my life wasted with the bumper lol. At least I remembered the bonnet pull lever this time... hehe
hope you havent drilled the airbox so its sucking in hot engine bay air?
Nope, I don't believe so. Drill most the underneath, then about 2/3rds of the front panel behind battery from the wing in, and the same on the rear of the airbox too, plus around where the cold air feed is.
Mike
