Mtec brakes advice
Hunnimonster
24
Hey, I'm thinking of upgrading my discs and pads soon, I've found mtec brakes and I wondered if anybody here has fitted them to their car. Also what size are the standard cupra brakes in thickness and diameter as there are 2 different sizes on the website.
https://www.mtecbrakes.com/brake-discs/seat/leon-2013/leon-2-0-cupra-280bhp-01-14.html
Also what pads did you go with for them as there are no front pads that will fit the car in the website.
Damo H
4,707
2,816
Car Length In Front
Fronts are 340mm on a non Brembo Cupra. Sorry not sure what rears are.
Reactions: Hunnimonster
Hunnimonster
24
I haven’t used them, but I have heard them and believe they’re good. But I’m willing to be completely and utterly wrong.
Yeah I've heard the same, my friend has them on his Lexus and he says they're good.
There is only one size of rears discs on their website so I'm guessing that's the correct size. I'll probably check my current ones before changing them though
Damo H
4,707
2,816
Car Length In Front
Their website could do with some work considering the only rear disc is bigger than the 2nd front one haha
But then BCS’s website could do with some work and they make the best exhausts so means nothing.
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
Has anyone used mtec discs before?
I haven’t but I expect I will when mine need replacing.
Obviously depending on what you plan doing for normal road use a disc is just a metal rotor. You probably won’t ever generate enough heat to need all the grooves and dimples etc... but they look good.
Track use and lunatic road use is another story
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
That was meant to be a smiley! :)
Hunnimonster
24
I have literally just noticed this Haha.
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
I was thinking of tracking in the summer at least once, just to see what the car was capable of.
Hopefully I'll have a few more mid by then as well :drive1:
Personally I’d avoid the drilled then.
As far as I know the mtec’s start life as a solid disc and the holes are added which will make them susceptible to cracking when they get very hot.
Hunnimonster
24
Yes, I heard this as well I was personally just going to go for the grooved discs. I drove the sub8 pack and felt that its brakes were quite sharp and they're grilled and grooved.
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
I would suspect that they are cast with the holes so the integrity and strength of the disc is maintained.
It’s a better process but also more expensive, I think the price of the Cupra Brembo’s and pads from a main dealer is about £850... I’d hate to think what a new set on an M4 or the like would cost!
Hunnimonster
24
Yeah it must easily reach into the thousands!
Brimfull
1,385
418
Wrexham
I fitted a set of mtec drilled discs to a corrolla t sport a few years back. Within 6 months they were heavily lipped. A friend of mine fitted a set to an Astra vxr and within a few months they had warped without having been pushed that hard.. Mtec buy very cheap discs and then drill or groove them themselves. They are not the quality of other aftermarket brands such as brembo etc. You get what you pay for I am afraid.
There is a large thread about mtec discs on a UK Subaru forum where a number of owners had a lot of issues with these discs.
All above was a few years ago now so don't know if the quality has improved over time but I wouldn't buy again.
Daire92
Cupra 290 DSG
Jan 6, 2016
288
200
Ireland
www.instagram.com
I've heard good things on this forum about the Vagbremtechnic J hook discs. Bit pricier than the mtec but the J hook design is the standard disc design for the BTCC so if its good enough for factory race teams its not a bad design. I plan on upgrading to these in the summer once my OEM current pads and discs are done
Hunnimonster
24
What pads are you thinking of putting on them?
Hunnimonster
24
Probably going to go with EBC Redstuff pads. They're rated for fast street use but they claim to be almost brake dust free which is a big draw for me.
Do EBC redstuff have brake pad sensors?
I remember reading somewhere they don't
