MPG in my 8v
cozzie121
64
i thought it might be interesting to find out how many miles others are getting to a tank.
its costing me £40 to brim the tank each time and the most i've squeezed out of it is 280 miles. the car is telling me i'm getting about 26mpg.
Mckellar
37mpg average in my 8v thats with mainly town driving/some motorway.
are u doing small journeys, i found my 8v takes longer to heat up as opposed to my 1.4 ibiza (naturally)
jcs356
Cordy owner
Jul 12, 2004
1,161
Englandland
Anything up to 400 miles from a tank of super on a long run.
A split crankcase breather pipe will reduce MPG as Peter says.
Smithy
Old School
Jan 17, 2002
965
Hertfordshire
About 300 miles for £40 is about right with average driving.
I just work it out like so:
eg.
£10 = 100 miles
3/4 of which is 75 miles
So £40 = 400 miles
3/4 of which is 300 miles
norm
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
26mpg is pretty shocking really, do you do a lot of town driving? my 16v makes around 32mpg with a mix
my mfa is showing average 20.3
tank takes 45L of optimax and so far done 165 miles and just below a 1/4 and the lights on
be lucky if i see 200
but that is just town/traffic driving 85% of the time and a quick blast about here n there when theres time / space
MarkJ
Ibiza GTi
Mar 26, 2007
437
Chesterfield
I can get anywhereup to 350 miles depending on how i am driving it, sometimes down around 250 if i have been giving it some. Do a bit of stop start in traffic to and from work though. Doesn't the mpg counter thing reset after every trip, mine always starts back at 0 every time i get in it so its always different depending on where im going.
1,837
Bristol
i've had mine since january and i've averaged 33-34mpg until now. that was mostly town driving but for the last month i've had a 25 mile each way motorway commute duing the week.
hopkinsgm
Do-doo-be-do-do-dooo
May 25, 2001
2,030
Swindon (occasionally)
...Doesn't the mpg counter thing reset after every trip, mine always starts back at 0 every time i get in it...
With the switch on the wiper stalk in position "1", the MFA readings reset after the engine has been off for 2 hours. With the switch on the wiper stalk in position "2", MFA readings reset when you reset them or the counters overrun.
I generally average 35mpg to 37mpg on regular unleaded - so that'd be about 380 miles to 400 miles if I ran it dry (bear in mind that while the tank is 45l, there's a certain amount of capacity in the fuel lines and the filler neck). I don't do a lot of town driving or short trips. Motorway economy seems to drop off seriously if I start cruising above 80mph.
Mckellar
37 like i said before on a private motorway journey at 75/80
25-35 normal town driving which i do most of
MarkJ
Ibiza GTi
Mar 26, 2007
437
Chesterfield
Learn something new every day. Cheers
cozzie121
64
Most of the driving I do is in the town, I’ve yet to take it for a decent motorway drive, but might take a long trip this weekend and see how it goes.
The oil temperature seems to fluctuate a bit too. After driving a while it’ll sit steady at 78’c, about ½ on the needle, then it’ll suddenly drop to about ¼ showing 70’c on the MFA. As you can probably guess, I’m fairly useless at anything mechanical
