Hi people,
Just had my 60K service and Cambelt change, great service etc from Camberley Seat. did need a new hydrolic tensioner tho
Now my MOT is due so i asked them to give it a once over... please bear with me as i have a few questions over the best routes to take. Any help or suggestions will be MUCH appreciated. Its a 210 LCR.
1) need new front pads and discs (discs are heavily lipped apparently) They quoted me £460 all in! i was thinking about getting a pair of DS2500 pads for £100ish but what are good 'not too expensive' discs to go for? (under 100 each) then i can get the lot fitted at stealers for £60.
2) need new front wipers, i'm sure i read somewhere that you can get aeros that clip straight onto the standard arms, am i right? and if so does anyone know where i can get them from and a rough price?
3) Rear silencer mounting bracket has broken - £60 to be re-welded. Now i'm sure that when i last had it serviced they told me that this wasnt really much of a problem. If i get it MOTed by someone local will it slip through un-noticed? or is it definatly worth gettin done?
4) Rear indicators emiting white light. is this just the stealers being OTT or should i replace them?
When i get it MOTed its going to a local garage so hopefully my HIDs will get through ok too.
Thanks in advance for any help you can all give. Great forum here and managed to find all info i've needed so far in my LCR ownership
Russ
Russ
