Most Cable routing
PaulusB
172
38
Hello what is the best route the get the most cable from the navi unit tot the virtual cockpit?
Thanks for the advice.
cairus
1,268
455
why? for the virtual cockpit only the fiber optic cable is needed from the 5F
Sorry translate Error.
Display backside
PaulusB
172
38
Yes fiber optic cable. i want to know what the best way is to route the cable behind the dash. So from the glovebox to the back off the cockpit.
cairus
1,268
455
see my change in the post. Remove the display with the frame. Remove the glove compartment. Then you will See the way for the LWL
cairus
1,268
455
yes, you want to lay the fiber optic cable from the 5F unit to the VC. Remove the glove compartment, remove the display with frame, remove the VC. then lay the cable
Reactions: PaulusB and Craig.
