Here is a picture:
The car needs to be lowered in order to look good.
I like. Just need centre caps to look better I think!
Here is a picture:
So can some one please summerise what max thickness alloys you can use on the front and rear,
also i'm running stock brakes and not looking to upgrade them.
Am I thinking a merc alloy of
8.5JX18H2
you will struggle on the front...with 8.5 18's rashcupra fitted them with maj arch modding
ET47
too high - even with 20mm adaptors it brings the et effectively down to ET27 which maybe to low on the front...
5X112
Wrong PCD 5x100 needed...112 - 100 adaptors will make it fit but you have loads of other issues that need adressing not just the PCD...i.e the thickness and ET of the wheel...![]()
will fit using 20-25mm adapters?
What the biggest or smallest offset you can get away with?
