MK4 1.8t Inlet manifold and Rocker cover interchangeable?
tomatcess
Stage 2 Onvi Yellow!
Nov 9, 2014
29
Norfolk
www.facebook.com
I have a mk4 Ibiza and just wondering if the AYP inlet manifold would fit a BBU engine? Only reason I ask is im thinking of fitting a front mount with the inlet port on one side and outlet on the opposite.
Also the rocker cover, is it interchangeable throughout the 1.8 20v Range?
Marcus_550
138
Stockton On Tees
fair as I'm aware the inlet manifold are the same apart from some are big port some small port and obv different sides, think u might have to extend the wiring on the throttle body if u move it to the other side of the car, rocker cover you need to get the one with the correct coil pack holes in as some are bolt down square shape and others like your current one are round
tomatcess
Nov 9, 2014
29
Norfolk
www.facebook.com
Cheers mate, ill have a bash at this soon!
